Author Topic: FL2100Z problem  (Read 1323 times)
PA3HGT
« on: July 13, 2008, 05:41:30 AM »
Hello all,
A friend of mine has a Yaesu FL2100Z with Cetron tubes in it.
When he changed the tubes he was forgotten to connect one of the tubes.
At the moment there is plate-current of 100mA in RX,can anyone give me some direction where i have to look ?
He has followed the neutralization procedure but the current reading stays.
73,Hans,PA3HGT
KA5N
« Reply #1 on: July 13, 2008, 06:28:46 AM »
The bias voltage is incorrect.  See the manual for adjustment instructions.  You have to remove the bottom plate of the amp to get to R4 so be careful.  Current with amp keyed and no RF input is 90 ma (in receive it should be near zero).  There could also be some failed component in the bias supply or a resistor that has changed value.
Allen
