Author Topic: Radio Dies when hooking...SOLVED  (Read 1221 times)
KJ4NUM
« on: January 10, 2009, 06:34:07 PM »
The radio was found to have 8.6 volts running through the chassis of the radio.   So if you used a multi-meter and touched a ground on the circuit board to another ground on the board, nothing.  But touch one lead to a negative area on the circuit board and the other lead to the chassis, you get 8.6 volts.
   What was it?   Faulty voltage regulator shorting out to the chassis through the heat sink!  Go figure huh?
   Replaced voltage reg and all works great!
N3JBH
« Reply #1 on: January 11, 2009, 07:16:36 AM »
10-04 Good buddy Smiley
