Author Topic: TL-922A to Tentec Omni Six  (Read 1881 times)
WB8BCO
« on: September 15, 2004, 05:34:18 PM »
I've been warned not to connect my ALC circuit until I find out what the ALC output levels of the 922A, and the tentec needs.  Now I'm affraid to use the amp until I find out more information.  Does anyone have experience using the 922A with a TenTec?
K6AER
« Reply #1 on: September 18, 2004, 12:24:29 PM »
The ALC output level from the TL-922 is 0-10 VDC and is adjustable via a pot on the back. The keying all though is 125 VDC and check if you radio can handle that level of voltage. If not, use a buffer relay from the Omni to do the amplifier
