Author Topic: APRS on PDA and GPS problems  (Read 3257 times)
AB8VE
« on: May 08, 2006, 05:26:06 PM »
I'm new to APRS.  I have a Kenwood TM-D700 and a Garmin etrex for the GPS.  This works all well and good.  I wanted to try and use my palm tungsten c to run aprs off of, but it seems that www.pocketaprs.com no longer exists.  Does anyone know where to get this software now?
Secondly, I have a Rand McNally road program for my PDA that will support GPS.  The only problem is, I can't find a data cable that will go between my etrex and my tungsten.  Any suggestions?
Thanks de
AB8VE
KC0VCU
« Reply #1 on: May 11, 2006, 02:11:43 AM »
Not sure which eTrex receiver you have, but most of them use a serial cable that allows you to deliver power for the radio as well.
To connect it with your Tungsten you will need a serial cable off of the Tungsten to provide that connection. In addition, you may need a variety of gender changers and possibly a null modem between them, depending upon which serial cable you use. I.e. if you get the serial cable you can sync with your PC over, (or use that one anyway) you will need both a female to female 9-pin gender changer, and a null modem. If there is a cable designed to hang a modem off of the tungsten available, you may need a 25-pin to 9-pin adapter if the modem cable ends in a 25-pin connector, or they may but together if it is a 9-pin connector.
If you are comfortable ripping cables appart, and soldering them to your own specifications, then feel free to break out the wire cutters, and dig in. I would recommend leaving enough cable hanging off the connectors so you can get the pin-out to wire color for each end, and solder just the tx, rx and ground wires across as necessary. If you can verify that power can be delivered to both, you may even bridge in a power connector to whatever power supply you can find that provides the appropriate power. Ultimately you will end up with a cleaner cable that you can fit in a lot more spaces than one with 9-pin connectors mid-stream, though even that isn't always going to work well for you.
As far as software for the Tungsten, I can't help you much. Haven't used a palm or WinCE device in years.
-Rusty - kc0vcu
KE4NYV
« Reply #2 on: May 29, 2006, 11:00:56 AM »
PocketAPRS is done with.  Mike informed me that he was too busy with paying gigs as well as the issue with multiple screen resolutions and options that Palm introduced in the last couple OS versions.  It was making it literally impossible for him to make the program compatible with the slew of Palm devices on the market, as well as the older devices with true serial (like me) were still using.
At one time, there was a guy giving out the last version of PAPRS that he had saved.  No idea who it was.  I used to have it, but I was forced to move over to APRS/CE on the Windows Mobile 5 platform.  Even if you find it, finding maps for PAPRS is a real bast**d unless you live in one of the bigger cities that Mike rolled maps for.
Jason KE4NYV
www.ke4nyv.com
RPC Electronics
www.rpc-electronics.com
