Author Topic: TS-2000 and APRS  (Read 10257 times)
W0PPD
« on: October 01, 2006, 04:20:28 PM »
Hello,
I have some questions concerning the TS-2000 and APRS.
While I have used the TH-D7AG ht and gps and mapsource software without any problems, I appear to be having difficulty with the TS-2000 and software.
Anyone out there running a TS-2000 and APRS ? If so what would be the best APRS software to use ? Possible freeware, and why. Are there maps with what you are using.
Please feel free to advise me why you like or dislike certain software and features, and which one setup well to work with the TS-2000.
Any and all input would be deeply appriciated.
James - W0PPD
KG4RUL
« Reply #1 on: October 02, 2006, 05:06:35 AM »
UiView works great!
Dennis KG4RUL
W0PPD
« Reply #2 on: October 03, 2006, 05:46:41 PM »
Well, UiView is not working for me. I have tried all settings and it just starts keying the main band and hangs up. Also notice that the Sta and Con lights never flash or come on.
I have the internal tnc set for 9600 baud, sub band and packet operation turned on in the radio. Settings in Ui-View match the above parameters.
I am at a loss. Any help her guys ?
de W0PPD
KC0VCU
« Reply #3 on: October 04, 2006, 12:58:28 AM »
I accept that I have some ignorance of the TS-2000, so I am not sure which part of the connection for the internal TNC is set to 9600. APRS packets are put on the air at 2400 in the VHF band, though the TNC and your computer need to speak at a common speed, which may be 9600. Most GPS receivers send and receive NEMA strings at 4800. I presume you are getting your own position from your gps receiver in UiView though so that should not be the problem.
You may be able to send at 9600 in the UHF bands, but I haven't been using that yet. (Not even sure there are digipeaters or a gateway around here for UHF.)
If you are planning on doing APRS in HF on the TS-2000, the speed gets knocked down even further to 300 baud.
Some of these may automatically be bing handled by the radio though. In that case it is the TNC to PC link that has to be 9600 (or some other common speed).
Another thing looking at the radio at Kenwood that comes to mind, is the tnc set up to do connected transfers or disconnected. APRS is not using a connected mode transfer, so it may not be accepting any packets it would receive as valid.
Obviously I don't know what all you have checked, so if nothing above helps, I'll be happy to throw out some more random thoughts...
-Rusty - kc0vcu
KC0VCU
« Reply #4 on: October 04, 2006, 01:30:34 AM »
A correction, aprs in VHF is sent at 1200, not 2400.
-Rusty - kc0vcu
W0PPD
« Reply #5 on: October 04, 2006, 05:48:54 PM »
Rusty,
Many thanks! Your random pitching of ideas did the trick.
TS-2000 com port needs to be set at 9600 baud, however, despite Kenwoods' advice, once I reset the cms file for 1200 baud, set the internal tnc to 1200 baud this dog walked ! Many thanks to all who worked with me and Rusty again thank you for all the great ideas.
73, and God Bless
James - W0PPD
G6XCJ
« Reply #6 on: October 01, 2007, 11:39:13 AM »
BUT DOES IT WORK?
Kenwoods have just told me that the TS-2000 is not designed for use with APRS/UIV?
And, after a week of 24/7 testing i have very reluctantly to agree. There are no entries for the Tasco Radio Modem for a start... there so many ifs and buts that i am truly fed up.
VA3ACZ
« Reply #7 on: November 25, 2011, 06:50:33 PM »
I was able to use the ARCS II software with the ts-2000 internal TNC to decode APRS packets.
KF4ULD
« Reply #8 on: October 13, 2018, 10:57:35 AM »
Hello all.  I have problems using the TS-2000 sub band at 9600 on a VHF frequency.  My goal is to run an APRS Digipeater/Igate on 144.35 at 9600 using AWG Packet Engine and APRSIS32.  Has anyone gotten their TS-2000 working this way?  I want 9600 on VHF on 144.35 as while in my mobile on the 710G, I want to talk UHF on the right side of the radio and have the left side working VHF at 9600.  Please share your thoughts or even your solution with me if you have any.  Thanks all.
Matt / KF4ULD
