Author Topic: VHF FM AMP will it work on SSB  (Read 2008 times)
W0OX
« on: February 10, 2005, 06:04:02 AM »
Will an 35-50 MHz Public Service Amp work on the low end of 6 meters with my MFJ 9406..the mode will be SSB and CW..I have a heathkit amp on two meters and need to toss a switch when I go from FM  to CW/ssb...
and am guessing I might have to modify the amp for CW/SSB.
the amp is a RF POWER AMPLIFIER, Model PA1-1AE,Also assume I will need to retune the amp for the high part of its range..I know others who have used this amp successfully on 6 mtr FM..Does any one have suggestions??
W0OX
« Reply #1 on: February 10, 2005, 06:14:39 AM »
Sorry,, I meant I need to toss switch to go from CW/FM to SSB
« Reply #2 on: February 10, 2005, 08:41:31 AM »
This is a no-brainer.
The PA1-1AE is manufactured by TPL in Los Angeles, which happens to be up the road from me.  I simply called them and asked.  Spoke with Chris in Tech Support.  Their phone number is 323-256-3000.
The PA1-1AE is a CLASS C only amplifier and will not support linear operation for SSB.  It's intended for FM use only.  It's also a narrow band amplifier, 4W maximum input power for 80W minimum output power, and only covers +/- 1 MHz of spectrum, so must be factory re-tuned for the 1 MHz you want to cover.  It's still a current model.
WB2WIK/6
W0OX
« Reply #3 on: February 10, 2005, 08:48:56 AM »
Thanks  much
