Author Topic: 820 vfo pin outs  (Read 3274 times)
MIGHTYMOUSE
« on: July 01, 2001, 02:53:13 PM »
I dont have the manual for the 820 vfo. The manual for the TS 820S has 8 pins.  I need to make a cable to connect the two.  The Transciever has the discription of each pin, but what I dont know is if it is a direct pin to pin connection and no cross-over of pins.  In other words does pin 1 on the transciever go directly to pin 1 on the VFO and pin 2 to pin 2 etc.  Or do any of the pins cross to a different pin, like pin 1 from the transciever goes to pin 2 on the vfo.  Thanks for your help.
KA1DBE
« Reply #1 on: July 04, 2001, 07:54:30 AM »
Send me an email and I will look at my owners manual....I believe it to be direct but I will check to make sure.
Guest
« Reply #2 on: July 04, 2001, 08:55:35 AM »
hi,
I own the 520 sister rig to the 820.
vfo manual and 520 manual schematics show
direct wire pin to pin   (pin 7 nc unused)
if you are using a dg-5 or aftermarket digital
display, pin 1 is vfo signal and 2 is shield to the
ext. display if used.
Just follow pin chart in the 820 manual and you
are good to go !
KB2NVN
« Reply #3 on: August 30, 2001, 11:39:54 AM »
You can download a free TS-520s manual from;
http://krasnodar.online.ru/hamradio/sch_eng.html
They dont have an 820 but the 520 will work better than none.
The manuals are at the bottom of the page under documentation. Most manuals are in PDF or MSWord.
The top of the page under Kenwood are schematics. There is a 520 schem. but no 820.
good luck, g, kb2nvn
