Author Topic: Need assistance with tube tester  (Read 1422 times)
N4UE
« on: November 14, 2003, 08:39:31 PM »
Hi all. I have a very mint Weston Model 981 tube tester that has a problem. This tester uses an internal oscillator (5 kHz) fed to the tube under test for checking Mutual Conductance (Gm). The problem is that the osc won't operate. I suspected bad caps (typical in equipment this old). The bypass and coupling caps were very leaky but the 3A4 tube is still not doing it's thing. I have another 'emission / short / leakage' tube tester, and the 3A4 checks good.
I have the schematic but the problem still evades me.
When the spring loaded Gm switch is operated, B+ is applied to the plate of the 3A4, (as it should) but still no 5 kHz output from the tube.
Does anyone have any experience with this model of tube tester?
thanks in advance!
ron
N4UE
If you're not the lead sled dog, the view never changes......
