Author Topic: Scratchy audio  (Read 2078 times)
AB2MH
« on: April 24, 2006, 01:34:16 PM »
I'm currently repairing an old GE C541 AM/FM tube type receiver I picked up at a hamfest (for 3 bucks!).
I got the radio to play (replaced shorted filter caps) but now the audio is really scratchy.
It's not the volume pot because I cleaned it up with deoxit and it still gives the same symptoms and I disconnected the input wire and the audio is smooth from a signal generator.
The bandswitch was cleaned out too.
What else could be the problem?
K3JVB
« Reply #1 on: April 24, 2006, 01:47:51 PM »
Check the tubes first..as with any old radio.
Audio amp first...and how is the speaker? They can get dry rotted, and cracked
good luck
AB2MH
« Reply #2 on: April 25, 2006, 04:47:08 AM »
Thanks for the suggestion.  Changing tubes don't really make a difference.  I tried changing them all one by one but no difference.
The AM section isn't sensitive at all, in fact I can only pick up WABC 770 here which is pretty close and it's at low volume with a slight hum (no scratching).
FM has loud scratching, but stations tune in.
This leads me to believe that the speaker is OK as well.  If I inject an audio source at the volume control pot's wiper, it sounds good.
I'm thinking leaky caps as well?  This radio has all ceramic caps (no paper/wax caps).  I replaced the electrolytics as well.
« Reply #3 on: April 26, 2006, 05:51:03 AM »
The 455KHz IF transformers used to be a relatively common cause of "scratchy" audio. I'm not sure of the cause because we just replaced them. It might have been the capacitors across the pins inside the can.
AB2MH
« Reply #4 on: April 26, 2006, 12:03:00 PM »
That's what I'm looking at next.  When I tap one of them it causes the scratching to change.
KA5N
« Reply #5 on: April 26, 2006, 04:12:13 PM »
Some IF transformers had the capacitors sort of held in place with clips.  These would get loose with age and vibration.  A simple cure was to remove them and replace with capacitors with leads soldered in.  No more problems.  The difficulty might be in figuring out what value the caps are.
Allen
KC8VWM
« Reply #6 on: April 28, 2006, 08:27:28 PM »
You might look at the audio output stage and insoect the interstage transformer.
Sometimes the transformer dries up and experience insulation breakdown between the windings inside them which results in static noises, pops and crackling sounds.
My two cents.
73 Charles - KC8VWM
