Author Topic: How does one tell if the feedline is radiating?  (Read 6354 times)
KF4YTI
« on: October 04, 2003, 11:46:45 PM »
I have built a J-pole antenna for use on 2 meters, and it appears to work great. I coiled the coax into 4 turns 5 in diameter 4 inches from the feed point, which many have suggested will prevent feedline radiation, and have measured SWR at 1.2/1, which I find acceptable. There's no evidence of TVI, and I find on VHF that high power settings are generally un-necessary, meaning that I usually run about 5 - 10 watts of power.
So, while I would guess my setup is OK, is there a good, established way to determine if the feedline is radiating?
Thanks!
Tim (KF4YTI)
« Reply #1 on: October 06, 2003, 11:49:34 AM »
Lacking complex test equipment, there are still ways...
Evidently, you have an SWR bridge of some sort.  Use it, transmit, and run your hand up and down the coaxial transmission line, gripping it, but loosely enough that you can slide your hand along its outer jacket.
If you run your hand up and down the coax for 20" or more and there is no change in SWR as measured at the transmitter-end of the coax, it is very unlikely the coax is radiating.
WB2WIK/6
AG4DG
« Reply #2 on: October 07, 2003, 05:23:19 PM »
Buy a field strength meter.  Cheap ones are sometimes available at hamfests.  (I bought one this past summer for only $2!)  There are also homebrew designs out there.
Now:
1.  Turn on your field strength meter.
2.  Bring your HT next to the field strength meter.  Transmit.  The field strength meter should respond.
3.  Transmit (key-down) with your HF transmitter.  Probe the shack with your field strength meter to see where the radiation is present.  The readings should be highest at the antenna and lessen as you move away.  When you are far away from the antenna, move the field strength meter towards the coax.  Touch the outer (nonmetallic) jacket of the coax with your field strength meter.  If the field strength meter does not respond, then the feedline does not radiate.  On the other hand, if the radiation increases as you approach the feedline even when you are far away from the antenna, then you have a problem with radiating coax.
This is so simple I'm surprised it isn't suggested more often.  Why go to all the trouble of RF grounding at the transceiver when it might not even be necessary?  (Actually, you don't really need an RF transceiver ground period.  Instead, use a balanced antenna or beef up the ground plane of the vertical.)
KT8K
« Reply #3 on: October 16, 2003, 03:01:52 PM »
I don't know how sensitive (maybe pretty good) or frequency dependent they are, but some older SWR meters made for CB/ham service have a field strength meter built in.  Look for the extra terminal or telescoping antenna on them.
I agree - use of a field strength meter is rarely suggested, but its an inexpensive and simple tool that works well in these circumstances.
Good luck es 73 de kt8k - Tim
5R8GQ
« Reply #4 on: May 18, 2008, 04:41:35 PM »
If it works, don't fix it!
N8CMQ
« Reply #5 on: July 20, 2009, 10:14:01 AM »
I use a diode on the input terminals of my Fluke DVM.
That is all a FSM is, a rectifier and a meter.
You can add an antenna, but it gets too sensitive then!
N8CMQ
N8CMQ   Jeff Retired...
KJ4EON
« Reply #6 on: August 01, 2009, 06:13:45 AM »
N8CMQ,
    How would I go about making one of those?  Alligator clips on my meter, any # diode?
       Tnx, Fred
KM3F
« Reply #7 on: August 01, 2009, 12:14:39 PM »
Putting antennas on VMs; you won't know what your picking up or where it is coming from.
4 turns on a 5" diam is way more inductance than needed for feedline choking for 2m.
On a J pole that is well matched, you don't need to worry about any of this.
