Author Topic: Capacitors  (Read 2425 times)
AB2MA
« on: March 02, 2008, 09:19:14 AM »
Having trouble finding mica and silver mica caps in the 1kv range.Can ceramic disc caps be used instead?
KE4DRN
« Reply #1 on: March 02, 2008, 08:00:20 PM »
hi stan,
are the mica caps damaged ?
http://www.justradios.com/capacitors.html#product
73 james
AD5X
« Reply #2 on: March 03, 2008, 04:39:52 AM »
Mouser Electronics (www.mouser.com) sells 500V and 1000V mica caps.  And you can always series two 500V caps to get 1000V (each capacitor needs to be twice the value needed when placed in series).
Phil - AD5X
AB2MA
« Reply #3 on: March 03, 2008, 05:27:01 AM »
Thanks for the responses.The caps are not damaged,they are missing.I checked Mouser and everything in the 1kv range does not have the right values.Can ceramic disc be substituted?The caps are for a Heath AT-1 xmitter.Tnx again,Stan
AA9XY
« Reply #4 on: March 03, 2008, 05:46:50 AM »
Try Antique Electronic Supply at www.tubesandmore.com, or RadioDaze at www.radiodaze.com. They should have the mica capacitors you are looking for.  Also, you'll probably have to pick something close to the original value, as a lot of the old, even numbered values are not made anymore.....i.e. 50 pfd has probably been supplanted by 47pfd, etc.
I wouldn't replace silver micas with ceramic.  The ceramics are more affected by temperature and will drift in value.
KA5N
« Reply #5 on: March 03, 2008, 10:54:34 AM »
In the case of the AT-1 (and other Heathkits of the same vintage) most of the components were WWII surplus.  Therefore some of the capacitors would usually have been disc ceramic rather than mica, particularly the .001 mfd which are just bypass or coupling caps and ceramics will work just fine.  The others should be easy to find.
Allen
AB2MA
« Reply #6 on: March 04, 2008, 10:01:22 AM »
Tnx for all the input,I'll be able to get started on the AT-1 now.Still looking for a transformer though(425-0-425 5.0 6.3),if anyone has one and wants to sell it let me know.Stan
KL7AJ
« Reply #7 on: March 06, 2008, 01:54:56 PM »
MA:
  What is the application of these caps?  If they are frequency determining components, you don't want to use ceramics.  If they're just coupling caps,,,sure.
eric
