Author Topic: How does this sound?  (Read 2659 times)
KC0LTV
« on: April 11, 2004, 10:17:44 PM »
For kind of an "all-around" type station (VHF/UHF weak signal/sat work, HF digital and SSB, 6m E-skip DX):
Kenwood TS-2000
WMR Rigblaster Plus Interface
Alpha Delta DX-LB Plus HF Antenna
PAR OA-50, OA-144, and OA-432 Horizontal Omni Antennas
Astron RS35M Metered Power Supply
MFJ 300W HF-UHF Dry Dummy Load (for testing)
KG4RUL
« Reply #1 on: April 12, 2004, 10:38:35 AM »
Let's See:
Kenwood TS-2000 - I have the TS2000X to allow a 1.2GHz uplink to AO-40 which, unfortunately, is now MIA
WMR Rigblaster Plus Interface - I have the MFJ equivalent
Alpha Delta DX-LB Plus HF Antenna - I have a G5RV and a Force12 Flagpole Antenna
PAR OA-50, OA-144, and OA-432 Horizontal Omni Antennas - I am using an MFJ 3 El, 6M beam with a RS rotator; M2, 2M and 70cm Egg Beaters with reflector kits
Astron RS35M Metered Power Supply - I opted for the Kenwood PS
MFJ 300W HF-UHF Dry Dummy Load (for testing) - An old Heathkit 'Cantenna' serves here
WOW! Close enough for Govt. Work!
Dennis - KG4RUL
KD5JFT
« Reply #2 on: April 16, 2004, 01:32:04 AM »
Hmmm...
Radios:
Yaesu FT-847
Yaesu FT-726R
Yaesu FT-90R
Antennas & Tuner:
MFJ Tuner w/HF/6M dummy load (need a vhf/uhf dummy load)
G5RVjr (lot too small for a full size)
GP3 (2M/70cm vertical)
GP15 (6M/2M/70cm vertical)
"Big Wheel" 2M horizontal omni
"Killer 6" 6M horizontal omni
Currently building eggbeaters for 2M and 70cm
1/4 wave groundplane in attic for use during thunderstorms
A270-6S 2M/70cm beam waiting to be put up
Intend to add second G5RVjr, log periodic beam for 6M/2M/70cm use, 2M and 70cm horizontal beams
Power Supply:
Astron RS-70M
MFJ 20A switching
124 Amp/hour battery bank
600 Watt inverter
Two computers (both old, one laptop, one tower)
Intend to rebuild even older computer
I also intend to add preamps (and maybe power amplifiers for vhf and uhf)
Very similiar setup to yours.
I am in the process of rebuilding my station after taking it down when cancer struck and they thought I was going to die (sure fooled them!!).
I should have pics up soon.
Craig Vowel
KD5JFT
N3ZKP
« Reply #3 on: April 16, 2004, 04:32:21 PM »
<< I am in the process of rebuilding my station after taking it down when cancer struck and they thought I was going to die (sure fooled them!!). >>
Congratulations!!!!!
Lon
