Author Topic: Power Inverter noise ???  (Read 2603 times)
VE3VID
« on: April 16, 2007, 12:33:48 PM »
The station I'm setting up is on a farm, on a meadow hill top, totaly in the clear. A Delhi68 tower, and an old travel trailer w/ woodstove.  1000ft from the house means no AC.  So I'm using 2 big marine deep cycle batteries, with a Xantrex 500w inverter.
I've noticed the power inverter makes some nasty howling heterodyne QRM on the HF rig. The tone and amplitude of the QRM changes based on what I've got plugged into the inverter.
I tried grounding the inverter chasis, and passing the power bar cord a couple turns thru a small toroid, but the noise persists.
Has anyone solved this before?  Do I need more turns thru a bigger toroid?  Heavy grounded shielding around the inverter & power cords?
Thanks for any suggestions
David
W5CPT
« Reply #1 on: April 16, 2007, 02:29:58 PM »
A lot of Inverters produce some less than an acceptable sine wave. Some of the older ones actually put a Square Wave. There was an article in QST not long ago, though I don't remember what month that dealt with just that. Try searching on ARRL.org.
Clint - W5CPT
KE4DRN
« Reply #2 on: April 16, 2007, 03:20:57 PM »
hi David,
Is running the radio off the batteries an option ?
What items are you running off the inverter ?
73 james
VE3VID
« Reply #3 on: April 17, 2007, 08:48:30 AM »
Hi James.....yes, the Kenwood 450 is powered direct off the batteries - made the most sense.
The inverter powers a laptop computer; Kenwood AT250 antenna tuner; a small desk lamp; and the rotator for the tribander.
The tuner could go 12v, but the laptop screen stinks when its running on its own battery cuz it goes to low power.
dg
K9KJM
« Reply #4 on: April 18, 2007, 10:36:41 PM »
I run my entire hamshack from the SINGLE deep cycle battery.
I would just ditch the  inverter that has lots of loss anyhow and get a laptop that can run directly from the battery supply.     Run it ALL directly from the battery..............  Eliminate the middleman noisemaker
K9KJM
« Reply #5 on: April 18, 2007, 10:40:28 PM »
LED lights suck lots less battery power, And only run the AC when you actually need to turn the rotor or tuner. Better yet, Get a manual tuner....... I am happy with my Nye-Viking MB-V-A..... NO AC required.
KE4DRN
« Reply #6 on: April 19, 2007, 03:35:44 PM »
hi david,
not sure of your laptop brand, some can run off
12vdc direct or use a travel adapter to run the
laptop from a car or airplane power source.
73 james
VE3VID
« Reply #7 on: April 20, 2007, 08:15:56 PM »
Alright lads.....yes all very good points. Buying 'another' laptop is low on the list since I just got this one, spec for the shack too.
James,  its a Dell P4 C640 2Ghz.  I'll do some snooping about to see if Dell has any options - good idea.
I'll see what ARRL archives has to say about inverters too
Thanks all........
David
