Author Topic: Need Help!  (Read 1873 times)
PUTERMECH
« on: June 10, 2002, 12:32:16 PM »
Pass the tech exam few days ago...looking at a chart of frequency...I see that a tech can use the follow:
6 Meter
50.1 – 54.0 MHz
2 Meter
144.1 – 148.0 MHz
1.25 Meter
222.0 – 225.0 MHz
70 CM
420.0 – 450.0 MHz
33 CM
902.0 – 928.0 MHz
23 CM
1240 – 1300 MHz
Is that all correct ?
KC8AXJ
« Reply #1 on: June 10, 2002, 10:25:34 PM »
CONGRATS!!
You are correct with the VH &UHF Freq.'s
Steve
KE6BGH
« Reply #2 on: June 24, 2002, 06:33:32 AM »
Actually, a tech can use the bottom 100 KHz of the 6 meter and 2 meter bands, as long as you use CW.  Techs have all the ham priviledges above 50 MHz.  Only the remaining Novice licensees are limited above 50 MHz.
Otherwise you list is accurate as far as it goes.  There are bands above 13CM, and all of them, on all modes, are also available to Techs.
Good luck and 73,
Dave
KE6BGH
