Author Topic: Icom 756 PRO III Interfacing with LK800C  (Read 1467 times)
W1RQ
« on: December 30, 2005, 06:00:15 AM »
Hello.
I recently purchased the ICOM 756 PRO III and would like to use it with my old Amp supply LK800 Linear.
The Amplifier for many years is being used with the FT1000D without any type of an interface.
I have purchased an Ameritron ARB-704 Interface Buffer. I have 4 optional Radio (Txd-SEND) jumper settings as follows:
1.    Low Systems 2.5 volt threshold (most common system used) 5 volts open circuit.
2.    Low systems 2.2 volt threshold (IC-706 series) 2.5 or more volts open circuit.
3.    Negitave systems
4.    Positive Systems This systems activites when ever the Radio line is pulled above 3 volts. Only 50uA of current apperas at the output terminal when pulled low, and open circuit voltage is 2.5 volts. This system consumes 1/2mA of current with 12 volts applied.
Question 1
Is the Icom 756 PRP III a Positive System  as described in option # 4 ?
Question 2
I also have a Heathkit SB200 with a Harbach SK-200 soft key modification. The circuit uses a 4N33 Optocupler and a  TRF9610
Hex-Fet. This was used with the ICOM 746 for 3 years with out any problems. Do you think it would be ok to use this with the 756 PRO?
Your assistance would be appreciated.
Regards,
Brad W1RQ
