Author Topic: small anttena for vx-7r  (Read 8534 times)
4Z7GBA
« on: March 05, 2011, 01:47:23 AM »
hallo
i want to buy a new Small antenna for yaesu vx-7r
i find too anttenas
dimond    srh-805s
and
comet      sma501 ducky
i want your opinion on this too anttena
witch is better ?
about the dimond i herd that there is fake ones
how can i know i what i buy is real or fake ?
KG4RUL
« Reply #1 on: March 05, 2011, 09:06:44 AM »
It depends on what you are going to use it for.  We have the Comet antenna on my Wife's VX-5R and it works great at her work location ( a hospital).  Of course, the 70CM repeater hub she accesses there is line-of-sight to to the building she works in.  I can also hit a 70CM hub, about one mile from my home.  As far as 2M, it is very hit or miss with this little antenna.
4Z7GBA
« Reply #2 on: March 05, 2011, 09:21:19 AM »
I need it for evreything that the vx7 can do
but most for vhf
N0SYA
« Reply #3 on: March 05, 2011, 10:04:16 AM »
Hi
I'm partial to the armpit tickler antennas, but if they're too long for whatever reason a standard duck with one of the "tiger tails" attached does very well and is much more flexible.
http://adjunct.diodon349.com/Radio/ht_tiger_tails_and_other_good_info.htm
http://home.frognet.net/~mcfadden/wd8rif/pdf/ht_antennas.pdf
If you have a clumsy child, you make them wear a helmet. If you have death prone children, you keep a few clones of them in your lab.
4Z7GBA
« Reply #4 on: March 06, 2011, 12:23:06 AM »
wich one of the two anttena
is better ?
i know that it is not going to be good as the original or an antenna with "tiger tails"
but from the two
wich is better
the comet or the dimond
KG4RUL
« Reply #5 on: March 06, 2011, 05:14:46 AM »
Looking at available, published specs, neither one stands out.  To reiterate, you are likely to be disappointed with the performance of either antenna on VHF frequencies, at other than line-of-sight distances.
4Z7GBA
« Reply #6 on: March 06, 2011, 08:20:22 AM »
so the best anttena is with tiger tails
i have one but i still hate it
stuk in my shirt all the time
may be i will try another one more luss
KD8HMO
« Reply #7 on: March 13, 2011, 12:12:25 AM »
I made the big mistake of buying a new VX-7R recently. The radio is a cute deal but performs terribly, expecially with the stock antenna. I am on my 2nd unit (warranty replacement 3 weeks after purchase). At the moment, I am using the Diamond SRH320A. Its a bit longer than the original antenna, but is very flexible. It will transmit on all 4 bands. I cant really compare it to anything else, because the radio still has horrible receive, even with the longer antenna. Dont expect any miracles with this radio.
KJ4VTH
« Reply #8 on: March 23, 2011, 06:28:04 PM »
I've had pretty good luck with the stock antenna.  Tried a couple others at a hamfest but they did not seem to perform any better in limited testing.
My VX-7 has very good receive (as does my FT-270).  I can hit repeaters 10 miles away from inside my house, 20 miles away standing on my back deck, and receive stations even further away.
