Author Topic: Swan Cygnet 270B Vox Issue  (Read 2535 times)
W9VOX
« on: March 21, 2011, 10:24:06 AM »
Really enjoying my recently acquired 270B but ran into an issue when trying to use the VX-2 vox module.  Hopefully someone has had the same problem and can point me in the right direction.  My problem is the that with the VX-2 installed the transceiver is always transmitting(keyed mic), no matter how low the vox gain is set.
Thanks in advance,
Greg W9VOX
« Reply #1 on: March 21, 2011, 12:33:27 PM »
Don't know the VX2, but similar units from other manufacturers had problems. Does it have a relay to drive the tx PTT? If so, is it stuck? Some similar units used under rated reed realys which did stick closed. Or if it uses a transistor driver to the PTT line, is the transistor short circuit?
W9VOX
« Reply #2 on: March 22, 2011, 03:57:20 AM »
Thanks for the reply. I've located a schematic for the VX-2 but don't have it in front of me right now. I'll take a look at it tonight and let you know.
