Author Topic: Kenwood TS-570D and HRD can’t communicate.  (Read 17004 times)
WALTERB
« on: June 20, 2011, 11:30:33 AM »
I bought a DB9 serial cable and hooked it up to the TS-570D.  I set Menu option #35 to 9600 baud, one stop bit.  I have Windows 7 device manager set the COM1 port at 9600, 8,N,1,   and have HRD set to 9600. I’ve tried every combination of settings on HRD for the TS-570.  But the Frequency read comes back with Zero.
What else can I check?
Thanks.
 Sad
AH6RR
« Reply #1 on: June 20, 2011, 11:43:13 AM »
Did you try to set it to 4800 baud? Also make sure the CTS and RTS are checked and the DTR is unchecked
AH6RR
« Reply #2 on: June 20, 2011, 11:52:40 AM »
Also if you are using a USB to Serial adapter some of them do not work with HRD
WALTERB
« Reply #3 on: June 20, 2011, 01:14:23 PM »
yes, I' have tried every combination.  Even if you check the DTR,  according to HRD it has it set to OFF.
WALTERB
« Reply #4 on: June 20, 2011, 01:16:08 PM »
I have a USB to the SignaLink USB, and a DB9 Serial cable to the TS-570D.
I'm not sure if that is what you are refering to?
Its a  Female to Female DB 9 pin cable.
« Reply #5 on: June 20, 2011, 01:23:24 PM »
I assume you checked baud rate set in menu on radio as well. You MUST use a null modem adapter or cable with a USB serial adapter or it will not work.
VA7CPC
« Reply #6 on: June 20, 2011, 06:04:22 PM »
Some rigs will only work with HRD when they're in "VFO" mode -- they will _not_ work in "Memory" mode.
If the TS-570D is in Memory mode, try VFO mode instead.
Also, does the TS-570D manual say that it will work with a "straight-thru" DB9 cable?  Or do you need a "null modem" cable?
                Charles
« Reply #7 on: June 20, 2011, 06:41:15 PM »
I own a 570 and have for many years and it does not care what mode it is in to RC it and it does require a null modem in circuit somewhere. Either in cable or adapter or it will not work. Some USB to serial adapters are made to control radios/modems and have null built into them. If you do not have it in circuit somewhere it will never talk no matter what setting you use. BTW I use 19,200  8N1 with hardware flow control with my 570.
WALTERB
« Reply #8 on: June 20, 2011, 10:09:56 PM »
I thought I was told that should be a straight DB9 and NOT a null modem cable?
WALTERB
« Reply #9 on: June 20, 2011, 10:11:58 PM »
Thats the problem. I was led to believe it was NOT supose to be a Null modem cable but a straight DB9 cable.  Looks like I'm in the market for another cable.
thanks
VA7CPC
« Reply #10 on: June 21, 2011, 12:13:06 AM »
You should be able to buy a DB-9 null modem adapter -- a plug and a socket, cross-connected.
              Charles
WALTERB
« Reply #11 on: June 21, 2011, 05:43:40 AM »
              Charles
I picked an ebay special for $5 shipped.
thanks for the help.
KS2G
« Reply #12 on: June 23, 2011, 08:51:52 PM »
You do NOT want a null-modem cable.
The '570 radios require a STRAIGHT THROUGH serial cable for rig control.
AD6KA
« Reply #13 on: June 23, 2011, 09:41:56 PM »
Suggest you post your connectivity difficulties here,
the QRZ HRD Kenwood Forum:
http://forums.ham-radio.ch/forumdisplay.php?20-Kenwood
GL ES 73, Ken AD6KA
WALTERB
« Reply #14 on: June 24, 2011, 07:05:24 PM »
Yes, both the NULL modem cable and the straight cable work (or fail to work) equally well at this point.
