Author Topic: FT-450at with Nomic  (Read 1724 times)
KJ4AGA
« on: June 26, 2011, 10:13:52 PM »
Does anyone have jumper layout tat you use for this radio?  I can't seem to get it to work very good at all.  CW translates very poorly and other modes are a wash as well although I'm listening, I haven't transmitted due to the spotty copy with hrd.
Thanks
Brian
KJ4AGA
KG4LMZ
« Reply #1 on: June 27, 2011, 05:43:15 AM »
I just used the layout labelled as "Typical Yaesu(R) RJ45 (8 wire) Modular mic connector radios" and it worked just fine.  It's the second one from the top on page 8 of the RIGblaster nomic manual.  For completeness:
PTT to 3
PTT GND to 2
MIC GND to 5
MIC to 4
No connections on GNDTIE, 1, 6, 7, or 8.
KX5JT
« Reply #2 on: June 27, 2011, 06:16:09 AM »
CW sent by humans generally translates poorly via computer.  Computers read computer generated stuff much better.  Just saying don't go by the CW decoding to tell if you really have a problem.
VA7CPC
« Reply #3 on: June 27, 2011, 07:45:04 AM »
You don't say what software you're using.
Try tuning to 14.070 / USB during the day.  With Digipan (or any other digital-mode software) you should see a bunch of railroad tracks with crossovers -- PSK31 signals.  If you can decode those, the "receive" signal path is working OK.
As the previous post says, software will only decode _strong_ CW signals with "perfect fists" -- paddle-sent, or machine-sent, code, with good signal/noise ratio.
          Charles
