Author Topic: Lightening arrestor  (Read 5420 times)
9H1FQ
« on: September 01, 2011, 01:16:37 PM »
Hi all.
I live in a qth which is very prone to thunderstorms in winter.
Which are the best arrestors, spark gap or gas filled ? If a gas filled flashes, does it need to be replaced ?
Which type is  ideal for a remote atu ?
An unknown gem of the Mediterranean sea is the Island of Malta. blessed with warm sun , all year round.
In just one day, you can see places which will make you travel in history from the Prehistoric temples throu the middle ages, the Knights of Malta, all the way to world war two. All the major civ
WS4E
« Reply #1 on: September 02, 2011, 08:24:42 AM »
Polyphaser is probably the 'benchmark' standard to use.
W8IXY
« Reply #2 on: September 02, 2011, 10:09:41 AM »
Just remember that whatever lightning is "arrested" (diverted from the equipment connected to the antenna), has to go somewhere else.  Be sure that you have a low impedance path to the "dissipation" place, i.e. ground, for the charge to go to.
Ted  W8IXY
W8JI
« Reply #3 on: September 02, 2011, 05:55:48 PM »
Hi all.
With either one rated for higher transmitter power on the antenna side of a tuner , it is very unlikely you will protect very well. The gas type is better and more reliable, but none are very effective if they pass transmitter power. This is especially true on the antenna side of an antenna tuner.
Your best protection is a disconnect system of some type, along with bonding of the RF cable entrance to the power mains entrance grounds.
After a while with many medium hits, or with one strong hit, they can go bad.
None. It isn't that simple at all. It is fairly difficult to protect a remote tuner, other than a full disconnect..
KI4SDY
« Reply #4 on: September 02, 2011, 06:48:54 PM »
Good advice!  Wink
