Author Topic: RFI-Free LED TV  (Read 11249 times)
W2MV
« on: October 12, 2011, 06:16:43 AM »
I am looking for any info from owners of LED TVs related to RFI, good or bad.
Thanks
« Reply #1 on: October 12, 2011, 08:37:44 AM »
I have three here of differing brands and sizes and have seen no RFI for them.
W2MV
« Reply #2 on: October 12, 2011, 09:42:37 AM »
Great. Which brands?
W3LK
« Reply #3 on: October 12, 2011, 01:51:30 PM »
I have a 40" Samsung that is trouble free, both directions.
« Reply #4 on: October 12, 2011, 04:01:18 PM »
JVC, LG, Magnavox.
W5DC
« Reply #5 on: October 12, 2011, 05:44:00 PM »
LG seems to put effort in making their other product like washers and dryers rfi free.
Dunc, W5DC
W7VO
« Reply #6 on: October 13, 2011, 02:28:15 PM »
I would stay away from the Samsung 55 inch model C7000 LED TV. I had a bad problem of RFI getting into the under cabinet touch sensors on 40M when running 1.5 kW to an inverted vee about 75 feet away from the TV, with the radio equipment in different building. It was causing the TV to change the input settings on its own.
I had a thread going on this previously. I tried ferrites everywhere to no avail, even inside the TV. I have heard from others with exactly the same problem, and the technician they sent from the factory ended up disconnecting the touch sensor board in the TV to fix the problem. Now I just use the remote and have never had a problem since.
73;
Mike, W7VO
K6KAP
« Reply #7 on: October 14, 2011, 05:24:51 PM »
I have 50 inch LG Plasma TV. I can't even operate HF when the TV is on. It generates tons of broad spectrum RFI. I know you were asking about LED, but I thought this information might be beneficial to all.
GL
Mach, K6KAP
« Reply #8 on: October 14, 2011, 09:21:18 PM »
GL
Mach, K6KAP
Not only are they BIG RFI generators, they are also VERY power hungry. You can run 4 or 5 LED HD TV's on what that Plasma takes. I have a 2+ year old 40 inch LED JVC that uses only 85 watts when I checked it. They push plasma because it is cheap to build and very near end of life cycle.
W2MV
« Reply #9 on: October 21, 2011, 10:29:00 AM »
Thanks to everyone who replied. We bought a Coby LED 32" TV (because the specs and picture looked good and it was on sale for $279) which will be installed within the next two weeks. I'll keep you posted.
W2MV
« Reply #10 on: November 09, 2011, 11:52:50 AM »
Update: The new LED TV was installed last week. When turned on, it generates broadband RFI on the 21 and 18 MHz bands. I can't detect anything elsewhere.
Here's what I've done: installed a toroid on the a/c line cord: no difference.
Installed a toroid on the RG-6 coax: reduced the RFI by 1 or 1.5 S units.
I unplugged the coax at the TV: RFI gone!
So it seems that the RFI is being conducted via the coax (and the cable TV coax acting as an antenna)  but 1 toroid was insufficient.
I'm considering installing a high-pass filter on the coax at the TV to see what happens.
« Reply #11 on: November 09, 2011, 05:31:35 PM »
You can find high pass cable TV filter that passes above 50mhz on Ebay for 10 bucks or less. I use a few here for insurance against RFI overload/swamping when running a KW HF as I use a external UHF TV antenna on a tower for HD broadcasts.
W5DC
« Reply #12 on: November 09, 2011, 06:36:14 PM »
You may find that a high pass filter on the cable going to the cable box disables the box controls.  I think my comcast box uses control signals around 10 MHz.
Dunc, W5DC
K8SI
« Reply #13 on: November 10, 2011, 01:57:14 PM »
I have a 52-inch Sony Bravia LED hanging on the wall in the room right next to my shack, and no problems either way...no RFI generated by the Sony, and no RFI/EMI effects in the Sony even when I'm QRO.  My antenna is hanging at the end of the house above the wall the TV is hanging on.
K2DC
« Reply #14 on: December 12, 2011, 04:12:39 AM »
We have two LED or LCD monitors and 5 LED or LCD TV's in the house.  I've never heard a peep and I'm active on all HF bands.  Never owned one, but I've heard from many that it's the Plasma's that are the nightmare.
Don, K2DC
