Author Topic: Plastic Clear Coat needed  (Read 25963 times)
N4NYY
« on: January 07, 2012, 03:41:25 PM »
I am restoring an AA5 from the 1950's, and the case is plastic. The color is like a Mahogany swirl, with a gloss shine clear coat. I am going to have to re-finish.
I test spotted automotive clear lacquer on the bottom, and the results were no good. It ate away at the plastic. Krylon mas a Fusion plastic paint, but have not tried. I asked on Antiques Radio Forum, and no one seems to know.
Is there any kind of plastic clear coat that I can finely sand and polish after it dries? Needs to be gloss and not interact with the plastic.
And yes, A5CUP, it is for the Edsel.
N2VWW
« Reply #1 on: January 07, 2012, 07:24:35 PM »
Try Minwax acrylic gloss. It is a water based wood finish that should not harm the radio's finish. Maybe somebody makes the same type of clearcoat in a spray.
Gary
KE3WD
« Reply #2 on: January 08, 2012, 03:09:51 PM »
Test the bottom with a clear acrylic spray finish.
http://www.krylon.com/products/crystal_clear_acrylic/
K8AC
« Reply #3 on: January 09, 2012, 10:54:38 AM »
You may be a radio collector and already considered this, but, are you certain that the case is not made of catalin?  The comment on the swirl and the gloss caught my eye and made me think catalin.  It would have been highly unusual for a manufacturer of a plastic radio case to have clear coated it with anything, but not impossible.  On the other hand, catalin can have such a high gloss finish that one might think it had been clear-coated.  The point is, a catalin radio is worth a considerable sum, but likely about nothing once one refinished it with anything.
73, K8AC
N4NYY
« Reply #4 on: January 09, 2012, 12:32:00 PM »
I do not know if it is catalin. It is the radio on the top here (F817) http://www.philcoradio.com/gallery/1958.htm#n. That is 1958. The problem with value is that it is worn and has scratches. I cannot see the radio being worth that without a cabinet restoration.
N4NYY
« Reply #5 on: January 09, 2012, 01:25:46 PM »
OK. Krylon clear acrylic was worse than the lacquer. I am going to try Krylon Fusion Clear for plastic.
K3WEC
« Reply #6 on: January 09, 2012, 06:14:04 PM »
I have been able to bring a nice gloss on old plastics by using plastic polishing compound.   Lots of elbow grease but the results have been good for me.
N4NYY
« Reply #7 on: January 09, 2012, 07:00:02 PM »
Problem is I have 1 or 2 area that need a refinish.
W8AAZ
« Reply #8 on: January 14, 2012, 08:27:38 AM »
Purely plastic from '58.  I believe a catalin would be much older. Specialised plastic polishes would be my first choice.  Maybe a Micromesh kit to polish it but any sort of polishing should be done by hand and is alot of work. The results can be quite nice.  The Krylon glossy clearcoat might be usable but I am pretty sure that plastic sets were not sprayed with anything by the maker, except in the case that they might be painted.
N4NYY
« Reply #9 on: January 14, 2012, 10:47:30 AM »
Krylon Fusion failed. I am left with the imperfections. I have to polish them out.
N3BSZ
« Reply #10 on: January 17, 2012, 05:34:19 PM »
Paste wax.  or google Future Floor Finish.  Model makers use it over decals on plastics.
N4NYY
« Reply #11 on: January 17, 2012, 06:24:39 PM »
I used 1000 grit sandpaper and Novus 1,2,3. Came out respectable!
KA3TRX
« Reply #12 on: January 18, 2012, 04:28:12 PM »
Just a thought - you might try one of those headlight refinishing kits.
N4NYY
« Reply #13 on: January 18, 2012, 04:37:39 PM »
I was thinking about the headlight refinishing kit. But I would be way in more financially that the radio is worth. Those kits can be about $20. I am not sure I can get $75 for this radio fully restored. And it needed 2 speakers, too.
AC5UP
« Reply #14 on: January 21, 2012, 07:56:16 AM »
Yo........ Vinnie.........
Your X-Rays came back from the clinic: http://news.sky.com/sky-news/content/StaticFile/jpg/2012/Jan/Week3/16153546.jpg
Looks like you're now qualified to captain a cruise ship!
