Author Topic: FCC dismissed vanity call application. Why?  (Read 9877 times)
WX2S
« on: June 18, 2012, 11:56:24 AM »
Hi, all,
With a shiny new Extra license in hand, I applied for a vanity call. Today I learned that the FCC had dismissed it. Reason given: Call sign not available.
AFAICT, it is. In fact, I gave a list of five, all of which were available.
What gives?
- Steve (KF2IO, and likely to stay that way...)
73, - Steve WX2S.
I subscribe to the DX Code of Conduct. http://dx-code.org/
W6BP
« Reply #1 on: June 18, 2012, 12:50:27 PM »
The call signs you tried to get are 2-by-1 and start with KL or WL.  Those calls are reserved for Extra Class hams in Alaska.
Here's where you can find more info:
http://wireless.fcc.gov/services/index.htm?job=call_signs_1&id=amateur
W6BP
« Reply #2 on: June 18, 2012, 12:52:31 PM »
Oops, just noticed that you tried an NL 2-by-1, as well; that falls into the same category.
WX2S
« Reply #3 on: June 18, 2012, 01:20:29 PM »
Crud. OK, thanks for the explanation.
- Steve (KF2IO.)
73, - Steve WX2S.
K0YHV
« Reply #4 on: June 20, 2012, 04:22:02 PM »
Actually, those are reserved for hams with a MAILING address in Alaska.  The station doesn't actually have to be in Alaska (HINT HINT).
N9KX
« Reply #5 on: June 24, 2012, 02:51:00 PM »
 Huh i can't figure out if you are a lawyer or a politician?    Grin
maybe i am old & crusty, but it is nice to see you have a 0 callsign and live in Iowa
« Last Edit: June 24, 2012, 02:52:46 PM by K9AIM » Logged
AB2RC
« Reply #6 on: June 28, 2012, 05:19:09 AM »
Well....
You could get a PO Box & remailing service out of Alaska but that would enable other stations to get credit for Alaska in DXCC & WAS, as there would be no way to show that the original poster's station was actually in NJ instead of where the license says he should be.
Alex/AB2RC
http://www.ab2rc.net
KA5N
« Reply #7 on: June 28, 2012, 07:50:28 AM »
Remember the old days when you used to have to get a new callsign when you moved
from one district to another?  Of course then you often could get a new prefix with
your old suffix.
But that was long ago.
Allen KA5N
N2EY
« Reply #8 on: June 28, 2012, 07:53:19 AM »
Well....
NOT TRUE!!!!
FCC simply requires a mailing address. Where the station is actually located depends on the licensee, and can be anywhere in US territory.
DXCC and WAS do not go by FCC license info. They go by either paper QSL or LOTW.
With a paper QSL, you have to indicate the station location for it to count for the award.
With LOTW, you have to create a location file that identifies where the station actually is. LOTW allows multiple location files, for the ham who has multiple station locations. For example, if I had a place at the NJ beach, and operated from there, I'd create another LOTW location file for those contacts.
In the case of remotely-controlled stations, Echolink, etc., what matters is where the radio stuff is, not where the control operator is.
All that said, the idea of using an Alaskan PO box to get a call that one otherwise can't get is against the spirit of the rules, IMHO.
73 de Jim, N2EY
N2EY
« Reply #9 on: June 28, 2012, 07:54:51 AM »
your old suffix.
Yep - 35 years or more, IIRC.
The reason they stopped it was because hams who moved across district lines complained about changing calls. Plus it really strapped the vanity system.
73 de Jim, N2EY
