Author Topic: Question PTC IIe Pactor Icom IC 706 MK II G  (Read 3327 times)
DL1FUG
« on: March 18, 2002, 02:21:27 AM »
hallo Hams,
I trie to connect a ICOM IC 706 MKII to a PTC IIe,
with the ACC plug I can receive, send but I can't get a connect. Perhaps I have a wrong pin???
Who has this installation running and can help me???
Many thanks
Udo DL1FUG
N1ZZZ
« Reply #1 on: April 17, 2002, 01:13:59 PM »
I will assume you are using the included cable that came with the TNC:
Pin 2-White-GND
Pin 3-Yellow-HSEND
Pin 8-Blue-power (13.8V)
Pin 11-Violet (purple)-MOD
Pin 12-Green-AF
The blue wire allows the radio to supply the power to the TNC so you don't need to use a separate power cable.
This information is from Icom America and was sent along with my TNC when I bought it.
Gd luck
Jeremy N1ZZZ
K9FV
« Reply #2 on: April 30, 2002, 05:11:13 PM »
Since you are sending and receiving, I expect you have the wiring connected OK.
Are you trying on the airmail system or normal packet?
Be sure you've checked and have all RF out of the system...  We need to know a good bit more than what you're telling about your system.
Ken H>
