Author Topic: SCS PTC-IIpro  (Read 2020 times)
LC1NAT
« on: July 22, 2002, 10:57:42 AM »
Hello from Norway.
I have the new SCS PTC-IIpro modem.
The skjema to connect to the radio.
8 PIN on the SCS PTC-IIpro
The pin 1 (Audio) output from the PTC PTC-IIpro to transmitter i have connect this line to the pin 4 on the ACC1 on the radio.
The pin 2 (GND)is ground to pin 2 on the radio
The pin 3 (PTT)is PTT to pin 3 on the radio
The pin 4 (Audio) from the radio to pin 5 on SCS PTC-IIpro
The pin 5 (13.8V)to pin 7 on the Radio
The pin 7 (FSK OUTPUT) I not sure i cand connect this cabel to pin 1 from the PTC to the transmitter
I cand resive RTTY/SSTV and CW an not send the CW the radio switsh to the TX and not signal is goving out.
Mus i have connect the cabel from pin 7 on the (ACC1) to the pin 6 on the (ACC2) with the switsh so i cand use the HF/50MHz and 144MHz
Pleas cand anybody help my so i cand use my SCS
Pleas cand you help my the cabling system is right.
If i must setup the parameters on the SCS pleas tel my how.
Meny thanks
Kaare Hagen
73's de LC1NAT
LC1NAT
« Reply #1 on: July 22, 2002, 12:07:24 PM »
Sorry my radio is IC-746
« Reply #2 on: September 18, 2002, 07:02:59 PM »
If the PTC-IIpro is like the PTC-II then the CW keying occurs via the PTT line. You must connect the PTT line to the transceiver key input (rather than the PTT line) in order to key it in CW mode. Since your transmitter is keying but no output, I assume that you have the PTC-II's PTT connected to the transmitter's PTT input rather than the CW key input.
The audio output of the PTC-II also has an on/off keyed tone (at the set mark frequency) so you could use that tone to modulate the transmitter in USB or LSB mode in order to generate a CW signal.
Using the CW Key line is likely the better option.
