Author Topic: Strange signal on 14082  (Read 3091 times)
KE4MOB
« on: November 19, 2001, 05:31:38 PM »
Can anybody ID the strange signal on 14082 kHz LSB?  It sounds like a harmonic of some sort.  The signal consists of 3 to 5 groups of extremely fast Morse dits with even spacing between groups.  Kind of like a burst data mode.  Any thoughts?
Steve, KE4MOB
KF4HEY
« Reply #1 on: November 20, 2001, 10:33:05 PM »
Steve,
Did you happen to catch the signal as a .wav file that you could post?  John Becker M5AML reported a strange signal several days ago and he posted this MP3 file on the DigitalRadio eGroup (www.qsl.net/m5aml/18.101MHz.mp3).  Does your signal sound like this one?  If so it may be an ionosonde probing the ionosphere.
Mike KF4HEY
KE4MOB
« Reply #2 on: November 22, 2001, 12:34:41 AM »
Nope, that's not it.  I'll catch it and record it.  The signal seems to always be around 14082 LSB when I hear it and sometimes I can hear a faint station perhaps answering??  It sort of reminds me of splatter from a Pactor signal, but the pattern is different than Pactor, and sometimes when I hear it, there are no Pactor stations on....
I'll post a recording.
Steve, KE4MOB
KE4MOB
« Reply #3 on: November 23, 2001, 07:32:20 PM »
Nevermind!  It was just a Feld-Hell signal...believe it or not, that's the first one I have ever heard.
Steve, KE4MOB
K9FV
« Reply #4 on: December 21, 2001, 10:09:52 AM »
What is a "Feld-Hell" signal??  Sounds intriguing??
Ken H>
K9FV
N1ZZZ
« Reply #5 on: December 30, 2001, 08:20:36 AM »
Hell modes (hellschreiber) used to hang around 14.061 USB or so, but since MixW included it, I have seen most activity around 14.079-14.082 USB.  If you want to see what it's about, I would suggest Griff's (NB6Z) website which has a lot of great info and some .wav files of most of the HF digi modes.
http://home.teleport.com/~nb6z/
Jeremy N1ZZZ
AK0B
« Reply #6 on: November 22, 2002, 09:24:49 AM »
After calling CQ a couple of days on 14063 USB running HELL FELD I moved up to 14078 USB carrier offset 1000 hz and found others running HELL FELD mode.  This is a real fun digital mode.    It is a digital mode with eye-brain combination of forms sort of paints the signal across the CRT in a double line.   Do a search on fuzzy modes and you will be able to locate a copy of the program or run MIXW2.
de Stan ak0b
