Author Topic: Palm m505 and a KAM ALL MODE TNC  (Read 2212 times)
KB2SSA
« on: March 02, 2003, 01:52:13 AM »
I have a Palm m505 with the serial hotsync cable and a null modem adapter. I have it hooked to my Kam All Mode and when I turn on the Kam I get the intro text from it and a cmd prompt as I am supposed to. Problem comes when I try to type a command. It will show up on the screen and I hit enter and it looks like the command went but the kam does not respond. It does the same thing with 5 different terminal programs.
If I hit enter enough times, the kam will respond every so often with an EH?.
When the Kam is connected to my PC via hyperterminal I can hit enter 100 times and the kam will spit back another cmd prompt for every enter I hit. As fast as 9600 baud will allow it. So I know the kam works.
Any ideas on why the palm is misbehaving?
Thanks.
mike
KB2SSA
KB2SSA
« Reply #1 on: March 02, 2003, 03:50:06 PM »
Never mind I fixed it. I was using a 9 pin to 25 pin adapter and it seems that it was missing 1 data line. Used a 9 pin gener changer and everything works perfectly!
