Author Topic: MFJ 1278 Problem with setup / commands Help Please  (Read 3791 times)
AA8P
« on: November 08, 2004, 06:58:24 AM »
I need a little help with MFJ 1278 TNC commands. I haven't used it for years and don't know what happened to the software. I now run a KAM so helping to get it running again has been a battle. I donated the TNC to a disabled ham in the area that I am trying to help get it running.. The problem we are having is when we try to connect it says" not while sever enabled " Also when we try to put his call in mail box with the mymcall command it doesn't recognize the command. We are using hyper terminal to run the TNC. Would it be better to use MFJ software and where is the software available? All replies greatly appreciated, Thanks, Ralph
N7XRD
« Reply #1 on: November 09, 2004, 06:24:09 AM »
It sounds like the mailbox is ON  it must be off I think for connects to be made..Have you tried a master reset?  this may be the way to go start fresh!
AA8P
« Reply #2 on: November 09, 2004, 10:23:05 AM »
Thanks Steve, we turned the mailbox off and that was the one problem. Now we can proceed with the setup. Thanks and 73,
WA8KSS
VE4HQ
« Reply #3 on: December 12, 2004, 11:42:04 AM »
software- do a search for Skyrider .(The original MFJ software).Its free.
