Author Topic: Computer Connection  (Read 1910 times)
KE7EEW
« on: June 10, 2005, 06:40:51 AM »
Is it possible to connect a HAM radio (THD7 Kenwood) to my computer and monitor any text packets that it recieves. Eventually, I would like to make a program that reads these packets & knows when the correct 'password' has come in.
Thats going to be linked to a basic stamp microcontroller that will flip a relay to cut down a high altitude balloon.
Any links etc. that anyone could provide would be very helpful.
Thanks!
- KE7EEW
« Reply #1 on: June 10, 2005, 12:20:26 PM »
You can do that. The manual should have info on how to connect a terminal program (running on the computer) to the internal TNC. You need to purchase or build a special cable.
It is also very possible to program a PIC chip to decode the packets as well as actuating your relay so that there is no need for a full radio and TNC like the Kenwood. You could simply use a receiver module to send audio to the PIC, making the whole thing smaller, lighter weight, and using less battery power.
KC7JDS
« Reply #2 on: June 23, 2005, 05:12:07 AM »
I'm not sure what digi-modes you're interested in, but try www. tigertronics.com. They have modems that connect directly to your computer or laptop, & then cable to the radio. They also have links to software you can download to make the modems work. A whole lot cheaper then the average TNC setup.
