Author Topic: Interface don't work when using ACC1 on Icom rig  (Read 2063 times)
WB0AXN
« on: March 25, 2008, 09:29:51 AM »
I finally found a 5-pin DIN plug locally and wired  it up to the ACC1 jack on the rear of my Icom 746Pro.
The recieve works fine, the PTT works fine, but I don't get any output signal from the sound card to the computer on pin #4.
When I connect the interface to the mic plug, everything works fine.
Does anyone here use the ACC1 jack on their rig instead of the mic plug??
Not sure if this is my problem, but the manual says to connect pin #4 to a modulator.  Is the speaker output on the sound card the same thing as a modulator??
Roland
WB0AXN
« Reply #1 on: March 25, 2008, 10:51:04 AM »
Please ignore my post regarding my interface problem.
Don't ask me why, but for some strange reason, I was thinking the "VOX" would work, when using the ACC1 jack.
It's not suppose to work....duh.
Please give me a "Dumbell-of-the-day Award"...!!!!
Roland (hanging his head in shame)
AA6YQ
« Reply #2 on: March 26, 2008, 01:13:00 AM »
Don't beat yourself up; there's a lot of considerations and factors involved in connecting a PC to a radio. While none of it is rocket science, there's a ton of detail. You overcame the problem by yourself; feel good about that!
        Dave, AA6YQ
#1 DXCC Honor Roll, DXCC Challenge 3000
WB0AXN
« Reply #3 on: March 26, 2008, 06:00:28 PM »
Thanks, Dave.....You gave me a better grade than I gave myself....at least, I didn't flunk.  Hi Hi
Anyway, things are working fine and I feel I accomplished something positive, for a change.
Roland
G0GQK
« Reply #4 on: April 05, 2008, 03:01:32 PM »
I was just about to reply as I have an ACC1 connection and it works OK, but like the previous correspondent said there are quite a number of things which can go awry.
I remember reading years ago about people who downloaded Digipan and said they had it running in 15 minutes! How did they do that ? I dunno !
Mel G0GQK
G3LIV
« Reply #5 on: April 15, 2008, 04:39:23 PM »
De Johnny G3LIV.
www.g3liv.co.uk
On the 746 is the ACC1 not an 8 Pin
and ACC2 a 7 pin.
The 8 pin has  RX AUDIO on PIN 5
                 HF PTT on PIN 3
         TX Audio drive on Pin 4
                Grounds on Pin 2
The 7 Pin has VHF PTT on Pin 6.
Get back to me if you need to clarify this
johnny@melvn.com
73...
