Pages: [1] 2 3 4 5 6 Next   Go Down
Author Topic: Linux has a catastrophic flaw...  (Read 52972 times)
« on: September 24, 2014, 05:16:18 PM »
It seem that Linux has a very deadly problem. Its called Bash Bug and it effects Linux and things based on it like Apple OSx. Basically it gets in through a networked like a camera or even light bulb controlled from a network and once hacked it is a doorway into OS. No fix at present.
Those of you that thought Linux was safe are wrong. Bug is rated catastrophic.
W4KYR
« Reply #1 on: September 24, 2014, 05:35:30 PM »
Um, lemme guess...we should kick all our computers out to the curb and buy some Windows 8 machines...right?
« Reply #2 on: September 24, 2014, 06:04:02 PM »
No I am just reporting the news. Linux is not inherently safe. MS does not look so bad maybe.
W4KYR
« Reply #3 on: September 24, 2014, 06:20:20 PM »
Simple fix
http://arstechnica.com/security/2014/09/bug-in-bash-shell-creates-big-security-hole-on-anything-with-nix-in-it/
"The fix is an update to a patched version of the Bash shell. To be safe, administrators should do a blanket update of their versions of Bash in any case."
Nothing to see here.....
« Reply #4 on: September 24, 2014, 07:11:28 PM »
Simple fix
That remain to be seen...
W0BTU
« Reply #5 on: September 24, 2014, 08:07:29 PM »
Imagine a violent high-speed head-on collision between two cars. The one car is a 2009 Win7 PC, and the other car is a 2012 Smartphone. The collision is so violent that the two cars are hopelessly entangled and cannot be pulled apart. The tangled wreckage, too, has a name: Windows 8.x. Dr. Frankenstein would be proud.  Grin
« Reply #6 on: September 24, 2014, 08:16:23 PM »
Your wrong they would call it a IPhone 6 which is still easy to bend and damage because of a bad marriage of parts.
KK4GGL
« Reply #7 on: September 24, 2014, 08:29:26 PM »
Patches issued:
    Red Hat Enterprise Linux (versions 4 through 7) and the Fedora distribution
    CentOS (versions 5 through 7)
    Ubuntu 10.04 LTS, 12.04 LTS, and 14.04 LTS
    Debian
    Opensuse 13.1
The patch for Opensuse 13.1 was applied before I knew about the bug. Too bad Microsoft doesn't work as fast.
Rick KK4GGL
W0BTU
« Reply #8 on: September 24, 2014, 08:37:05 PM »
Patches issued:
Well, not quite. See the discussion at the bottom of https://access.redhat.com/node/1200223
Anyway, thanks for bringing this to our attention, John. Seriously. I just manually patched one of my Linux boxes (using iptables) until the real fix becomes available.
My Xubuntu box patched this bug this morning, I believe.
KK4GGL
« Reply #9 on: September 24, 2014, 08:53:19 PM »
Patches issued:
You do realize he wasn't doing this to be nice?
Rick KK4GGL
AG6WT
« Reply #10 on: September 25, 2014, 08:11:05 AM »
To be fair, this is not a "Linux" bug but rather a shell bug.  While bash is the default shell on most Linux distributions, users and admins are free to install anyone of the other popular shells such a ksh, csh, tsch, dash, etc.  Ubuntu uses dash and not bash for OS services so it may not have the same risks as other Linux distributions that use bash for everything.  And as you pointed out the bug is also found on OSx installations, which by the way, is not Linux but a Unix variant based upon the Mach kernel and BSD.  Furthermore, Windows servers using bash, like Git for Windows, might also be vulnerable.
I've been looking around on the security forums and the fix has come out rather quickly.  The worry isn't so much devices like webcams and routers.  Bash is rather heavy (everything and the kitchen sink kind of heavy) so embedded systems tend to use something smaller like Busybox.  The primary worry is that legacy systems, like old ftp and webservers that aren't actively managed*, won't be patched.
* This is one of the "problems" with Linux. Once you have it configured to provide a service, it can be up for years without any incidents and it is easy to forget to check in once and a while and see if it needs any preventative maintenance.
« Reply #11 on: September 25, 2014, 09:18:03 AM »
Bash is not natively supported in Windows and can be supported only through emulation so at present it is not a threat for security.
K0JEG
« Reply #12 on: September 25, 2014, 10:41:31 AM »
Hardly catastrophic. It might be an issue if you aren't properly firewalled or have a specific situation with Apache web server and CGI scripts, but if you're potentially affected, you're already likely patched.
And as for W8JX's eagerness to gloat, the point isn't to "call the kettle black" but to fix the problem and move on. Even for Windows boxes. The haters who constantly mock Windows for exploits found generally fail to notice the installed user base. If Linux/Unix was as big a target I'm sure there would be many more exploits found. That said, having millions of coders looking over the source certainly helps get these issues resolved quickly.
« Reply #13 on: September 25, 2014, 10:55:13 AM »
I think you miss point here. It is not about firewalls, its about internet accessible devices like cameras and home security and lighting and such that provides doorway past firewall in Linux.
NN4RH
« Reply #14 on: September 25, 2014, 02:30:40 PM »
Wow. Linux has one flaw! (Already fixed by the way).
How many thousands of security vulnerabilities has Windows had over the years?
Pages: [1] 2 3 4 5 6 Next   Go Up
